Have a sr651 on a zero turn. Bought new, 7 yrs old, 430 hrs. Always well maintained. Started it today, ran about 2 minutes and sputtered, like it was running out of gas. I reached around to switch tanks, and it started smoking like crazy. White smoke. No obvious metallic sounds...I shut it off and towed it back to the barn. It’s will start, but run only on full choke....lots of smoke. I pulled valve covers....everything moves like it should....i readjusted the rocker clearance.....no change. I did a compression check. 160 in both cylinders.....really?
I’m thinking heads gasket?. Any thoughts appreciated.
