We have a 2010 John Deere X300 with a Kawasaki engine Model FH491V-DS04-R. It has 279.4 hours on it. It starts and runs fine when you first start mowing, then when it heats up it starts to run very sluggish. If you let it sit and cool down it will run fine again.it's almost like when you go through tall grass and it bogs down, but it is not in tall grass. I have cleaned out the mower deck, checked the belt and belt tension, replaced the fuel filter, checked the air filter (good), cleaned out the carburetor, and replaced the spark plugs at the beginning of the season, also checked the coils by removing one spark plug wire at a time. One weird thing when I rechecked them is that the spark plugs all around the outside of them where you screw them in, the metal is all white, like they are heating up. The engine area is clean and nothing looks clogged so we are at a loss and looking for suggestions. Thank you!
~F
~F
