Notamechanic
- Mar 26, 2021
- 3
Briggs and Stratton 5hp 130202 3166-01 Code 90102427
Hechinger by MTD Tiller Model 211-381-372/06-054290
Tiller was running fine a week ago, wouldn't start this week, and when starting to troubleshoot, noticed throttle cable was having no effect at carb, nothing moving. Have searched web high and low and found many diagrams and videos, but none that I can see match the set-up on this engine/tiller. The throttle cable is attached to the mechanism attached under the gas tank and their is action/it moves....spring is attached to same mechanism so that when at full throttle position, spring applies downward pressure to governor arm. Single linkage from governor arm up to carb is in place and intact, but there appears to be nothing to cause linkage to move upward to action the butterfly in the carb, only the spring holding downward pressure? I'm thinking something is missing/broke/gone, but don't know what. Best picture I could get of current state is attached. Any help is appreciated.
