Need help with riding lawnmower
bstan943
My riding mower is extremely difficult to start and most of the time won't start at all. Its a briggs & stratton 17hp ohv 501cc single cylinder. And when I do manage to get it to start it acts like it wants to die then runs decent for another 5-7 seconds then acts like it wants to die again, over and over. Turn it off and it takes forever to get it crunk back up, if at all. Its getting fuel, spark is good, compression is good, took the valve over off and rotated engine and valves aren't stuck. The plunger in the bottom of the carb is working fine too. Anyone know what might be causing this?
The two main causes for this problem are, improper valve clearances and improperly set or dirty carb. I would start by checking the valve clearances and if that does not help clean and rebuild the carb.
