wilburn cox
- Feb 24, 2014
- 40
- 107
I have a Poulan 16" chain saw won in a sales contest in 1977. Yes, I know it's old. I have a Stihl pole saw and a Stihl 18" saw and love them. This little Poulan was great for limbing until I placed it in a shop for tune up.
The little saw is in or (was) perfect shape, kept in the case when not in use and properly cleaned and stored after use. After being in the shop it was very hard to start. Pull ripe would almost break my wrist. I set it aside until I had time to go through it myself.
I tore it down, ordered and used piston and cylinder (could not locate a new one). The Piston and cylinder was in great shape. I installed new rings, rebuilt the carb, new plug and etc. All back together and it did not correct the problem. Without plug installed the pull rope is easy. With plug installed it almost takes two men to pull the starter rope. After jerking extremely hard for several pulls it will start but I know something is wrong. It feels like it is firing at the wrong time. I replaced the flywheel key but it did not change.
Could my problem be in coil?? yes, I know I have spent more than the saw is worth but I'm a hard headed Texan. I repair all my mowers, tractor and the Stihl saws. I enjoy working and learning but now I'm frustrated.
Any suggestions will be appreciated. I love the forums.
Frustrated Texan
Frustrated Texan
