ok, i put on different flywheel, and installed replacement ignition module....SO FAR SO GOOD! started right up, and have mowed several times now without problems! i do have one other question concerning tuning the carb. i took apart the carb last night and cleaned it out ( i noticed that float was sticking, and was able to fix that also) but as i put it back together i noticed that it does have an adjustment screw for air mixture on from side of carb. what is the best way to adjust that? just turn in slowly til it starts crappin out, and back out a little (like the old carburetors on cars??) anyone know? thanks, Rick
