- May 6, 2010
- 12,058
Mike what you are looking for is a C shaped item that is part of the right rear frame/ fender assembly. Looks like the C on the deck where the cable attaches to the deck but smaller.You may be able to see it when looking up from behind the right axle tube on the inside of the frame. Also removing the battery if under the seat, may give you assess to that item.
You have slide the cable up behind the right rear axle, insert the Z into the deck engagement lever ( removing battery under seat will give somewhat better assess) pull the rubber accordian off of the winged end of the cable, Slide the cable through the opening in the C, snap the wings into place like you do on the deck end and then put the accordian back down on the wing end.
What you are looking for is hard to reach, and even harder to see if you don't know what you are looking for. I did find a picture of what you are needing but it is security protected due to being a dealer only item. the C tab should be located slightly above the right rear axle.
