CrBriggs87
- Jul 13, 2019
- 3
- 6
I have thouroughly cleaned the carb (twice), changed oil, air filter, gas, spark plug, etc. Literally everything. However, When I removed the case, I found this part that was just kind of free floating. See attached picture. Seems like there might be a missing spring or some sort of connection there. I even found the exact diagram for the model on the Sears website but it did not show this piece. Can't find anything about it online. Any help is greatly appreciated! Thanks
EDIT: It will run for three seconds with a spray of starting fluid but that's it.
