Need help with an old Bunton mower plz!!!!
Mbrasil
I am new to this forum so sorry if this has been covered, although I couldn’t find anything.
I recently got an old belt drive Bunton 52 in walk behind with a 14hp Kawasaki on it. It runs great, but needs some odds and ends. The tag on the mower deck says the model number is “B52-14k” with the UUB serial number. I’ve looked all over and can’t seem to find that as an actual model. I need to replace deck and drive belts (basically every belt) a spindle with the pulley and brake band hub and one of the wheel drive pulleys.
if anyone has any insight on these or what the bobcat/goodall version is I would appreciate it. I’ll attach the pictures I have.
Hammermechanicman
Yours is new compared to mine. Mine is a 36" with a 10hp Tecumseh VH100. Most Buntons cane in 2 types. The older variable speed pulley type and the newer gear transmission. Except for a few parts for different deck size most bunton parts are the same for each type. Find a parts list for your deck size and type and the belts will fit.
