Need help on an old rider
TonyR
Hi, I'm a newbie and hope someone can help solve my problem and hope I'm posting in the right place.
I bought an old 1996 Murray 12 hp, 38" and had no problems til now. I tried to download a manual for it but couldn't find a listing. It's a Mod. 38702X8D.
Ok, the brakes didn't work when I bought it but have been taking it very easy until i could try to fix them. Well last week I started rolling downhill slowly and the only way to stop it was shift into 1st. When I did the drive belt popped off and I finally think I figured out how it was routed. So I go about 35' and it just stopped and wouldn't pull in any gear. The belt is still on it. Since the clutch/brake don't feel right I think maybe I need to adjust the clutch but don't know how.
Thanks in advance for any help! :smile:
chance123
That clutch is a simple "loose/tighten belt" clutch with an idler. If you shifted into 1rst while it was rolling, you might have damaged the peerless transaxle
TonyR
Chance I sure hope I didn't. Other than the no brakes it ran and looked new. Is there a way to check for sure before I pronounce it dead?
Thanks
tybilly
Thanks
damaging the tranny still isnt a big deal,hopefully just an input shaft or some keys a tube of techumseh grease and its back to good.
TonyR
Thanks tybilly for the encouraging words, I'll let you know shortly. :thumbsup:
tybilly
youre welcome,i had a dana foote tore down 6 times before i realized(or admitted) the gear on the input shaft was not "machined" that way..lol
