parkkilamichael
- Mar 18, 2013
- 2
- 2
I have a EBZ7001 blower and it has been giving me trouble. The engine runs fine for about ten minutes then it will slowly start to bog in and out. Sounds like the engine is sick and holding back. It will bog in and out for about another ten minutes then it will finally stall. If it's restarted, it continues to bog in and out for a while and eventually stalls once again. If the blower is left alone to cool down and is started fresh....... it will run fine for about ten minutes and then continue to bog like before. If you could give me any tips how to correct this problem I would highly appreciate it since the landscape season is coming soon. I've used new plugs, intake and outtake is clear, and I've also put in a new carbureater so I know the carb is not the issue. maybe new gaskets? please get back to me. thank you.
