I have a 54" cut troy bilt with 25hp briggs engine. Over the past few months I had the engine out to replace a leaking crankcase gasket. I also replaced all the exhaust, intake, and crank seal as well. I replaced all the belts, the fuel filter, pump, and hoses, as well as normal spark plugs, air&oil filters. I got the mower running in my garage and ran perfect, I start cutting grass and after about a minute or 2 it started dying on me, I turned blades off, that didn't help. Then when I try to start it, it just kept cranking not even trying to fire. Let it sit overnight, I went out today was able to get it to start after a while, starting cutting grass and same thing, any ideas?
