I have a 46" Craftsman riding mower with a 21hp B &S engine (model #331877-1371-B1). I got it from my parents and it's from 2010. It has sat for several years because they did not use it. I flushed the gas tank. I replaced the fuel filter and spark plug. I also replaced the battery. The engine cranks and cranks but it will not start. Is it possible the carb is "stuck" and gummed up? Do I need to replace the carb? Can anyone help me with finding the right carb to order? Can I just take the carb off and "clean" it? I don't have a carb rebuild kit.
Are there other things you would recommend that I check that might be causing it to not start?
