Need Help ASAP!!! Removing pine straw
CleanStrong.NET
Greetings everyone!
I have a client that needs me to remove pinestraw from his backyard (aprox 6,000 sqft) so he can start seeding for grass.
What's the best way to clean up all that pinestraw???
Thanks guys
Well 6000 sq ft is pretty small to me, I would start raking.
With my pine straw rake pictured below I could do that in about 20 minutes or more depending on obstacles. Everythingattachments.com has a new model with replaceable tines that I would recommend, cost is about 300 to 400 depending on width.
I should add that the third picture shows what one pass will do, and it doesn't hurt the grass either. The lawn pictured is from a customers new purchase and the grass was about gone from too many pine needles snuffing it out. The rake is light at about 70 lbs for the 6' model shown and I also add about 80 lbs of weight to it when using it to dethatch dense lawn areas.
This will work with any cat 1 3PH tractor.
Awesome idea I'm going to look into it I have till this Friday to come up with the best strategy.
Thanks again!
Where can I get one of them because it would come in pretty handy
Sent from my iPod touch using LMF
I had to do a smaller area like this. I used a sweeper and it gets it done but u have to go over it A few times just to get it good.
