After a single mowing, my mtd riding mower won't start again. I have checked battery, solenoid, and the key switch, all are fine. Then i noticd that when i try to bypass the solenoid the engine turns, together with the blades!!!
blades' lever seeems moving in full range, however the belt that connect the engine to the blade tray is tight all the time!
