Hello:
My "new" 5247 mower will no longer start! It started pretty good at first but now it will not even kick.
I experimented with the number of shots of prime I put into the engine but to no avail. The PO wrote that it took 6 shots of prime cold and none hot for one pull starts. Yes, the primer is functioning as it should.
I replaced the plug with a good one.
The compression is great.
It appears that there is no air/fuel mixture reaching the engine. I shot carb cleaner into the throat of the carb to see if this would get it started but that too failed.
Any ideas as to why this engine quit working? Could the reeds be blocking the flow of the mixture? I have never een the reeds fail to open but I have doused them with carb cleaner just for luck.
I am going to place some gasoline or carb cleaner in the spark plug hole and see if the engine will start. If it starts this way then I will know that it is a blockage of some sort! But if it is not getting any air...
As I am typing this, I have the carb soaking in a cleaner/ultrasonic cleaner.
Any suggestiuons?
Tia,
Franchi
Any suggestiuons?
Tia,
Franchi
