Convert
- Jan 24, 2020
- 6
- 29
The engine is a 22 horsepower Kawasaki FH 641 V I installed an oil cooler that fits the 721 version of the Kawasaki engine, the hardest part of the whole job was washing my hands, as a side note this engine originally did not come with the oil cooler, but the oil cooler for the fh721 ,it is is a direct replacement ,just have to change the oil filter joint from the original joint for the filter to the one that comes with the kit works.
I did have to buy an 3/8" inside wrench made by Irwin fits s into the original joint, counterclockwise remover it you can also use it to put the new joint in, if you replace it would the original joint not the one in the kit enjoy.
I have pictures but I cant figure out how to resize the pictures to post here.
CONVERT.
TOM
CONVERT.
TOM
