anthony21078
- Apr 15, 2019
- 1
- 1
Moved into a new home last June and the front and back yards were in semi-decent shape but they need a lot of help. I wasn't able to tackle this project in the fall when I should have but I would like to attempt to correct the yard in the next 2 weeks.
Ideally I wanted to use a sod cutter and remove everything to start from scratch. I don't have the ability to to dump all the material so I'm hoping there's an alternative to grow a respectable lawn. I'm not looking for a golf course but rather a respectable green lawn. There are quite a few areas along the fence that are heavily shaded. This is what I came up with so please tell me if this would work.
1)Spraying the problem spots with RoundUp for Lawns to hopefully take care of the weeds/dandelions. Ive never used this stuff but I figure its worth a shot since I will be re-seeding the whole yard. Was planning on spraying tomorrow to get the ball rolling
2)Aerate entire yard
3)Add a layer of topsoil to entire yard and fill in uneven spots
4)Over-seeding entire yard. I would like to use Jonathon green grass but not sure which type to get. Fall Magic and Dense shade mixture. Opinions?
5)Starter fertilizer on top
6)Water 2-3x a day
6)Water 2-3x a day
