My engine wont start.
LaWn GuY
It started then was vibrating I sped It up then It acted like It was going to stall so I slowed It down then It just shut off and wont start back.
gfp55
Maybe you could post Model# serial# of engine? Have you done anything like check spark plug for spark, air filter, fuel filter,etc?
If it was vibrating, did you hit something? First thing I would check is a sheared flywheel key.
LaWn GuY
I figured It out the push rod got loose and was not making contact with the valve.
