My Clutch won't activate
Sam Tim
Hello, I have a Great Dane Zero Turn with a Kohler courage 25 HP motor on it. I just replaced the clutch, but when I tried to burnish in the new clutch I get nothing. The clutch won't activate. I checked the troubleshooting portion of the clutch manual and it said that if the engine's connector wasn't putting out 12-14 volts that the clutch wouldn't activate. I checked the connector with the PTO engaged and it read like .35 volts. What's wrong?
Bad PTO switch, faulty safety switch, blown fuse, broken wire.
