[email protected]
- Feb 11, 2013
- 37
Hi all,
I have a 16 horse power v twin engine model: 402777 that I have put many parts and hours into but will still not run! The specific details are; I choke the engine to start, but have to leave the choke on to keep running. After running for 2 to 2.5 minuets or less sometimes the engine dies but will start back up and repeat the same process.
I have replaced the the fuel lines & filter, ran heat moisture remover through the fuel system, thoroughly cleaned and rebuilt the carburetor and fuel pump, and finally replaced both head gaskets. I have checked both coils with a spark tested to make sure there is spark until it dies, confirmed working. I am at a complete loss here, any suggestions would be greatly appreciated.
