LB7268
Here are my 3 lawn boys.
On the left is my 2001 10550. I bought this slightly used in 2003. In 2006 or so I went to start it for the first time of the season and it ran for 10 seconds and died. I parked it for 4-5 years and was gonna trade it for something else. They hardware store in town basically said we'll take it off your hands. I then decided I have 2 lawn boys ,why not get them both going. I tore into the 10550 and found I had scored a piston . I then put a new piston and rings in and has run perfect since. The pilot jet has since been replaced with a 42.5 Briggs. I am so glad I decided to keep this as it runs great now.
Next is a 7260 deck. ( original was cracked and I can't remember what model number was) D600. My dad bought this used in the mid eighties and I mowed lawns in late 80s- early nineties. It then layed in my dads garage until I moved out in 2001 and acquired this mower. The deck was cracked and I found another from the hardware store junk pile. I used this from 2001-2003 when the governor started acting funny. I then got my 10550 and parked this til 2010 or so. I then pulled this back out and fixed the governor. It now runs perfect and still has 90 psi compression.
Last is a 1978 7268 that I scored at a rummage sale for $10. I brought it home and started first pull. Then it sat in basement for 2-3 years and when I drug it out wouldn't start. I decided to do a full on rebuild and put new piston rings and all. I got new decals for tank and painted all up.
I now use all 3 mowers in the rotation
This is my first post so I thought I would make it some eye candy for you. Thanks for having me aboard.
