Export thread
my 14 hp kohler smokes terribly when run with crankcase full of oil
#1
J
jimbojam
does any body know why my motor sucks oil out of crankcase down to add mark then stops smoking till u add oil
#2
EngineMan
EngineMan
You don't say which one you have...! but have you check the breather pipe..?
Engine Uses Excessive Amount of Oil
1. Incorrect oil viscosity/type.
2. Clogged or improperly assembled breather.
3. Breather reed broken.
4. Worn or broken piston rings.
5. Worn cylinder bore.
6. Worn valve stems/valve guides.
7. Crankcase overfilled.
8. Blown head gasket/overheated.
#3
J
jimbojam
Re: my 14 hp kohler smokes terribly when run with crankcase full of oil mod.cv14 st 1
4. Worn or broken piston rings. no sir i dont know about breather pipe??? it's a vert.shaft 1 cyl.oh valves
thanks for your time WHAT WOULD YOU DO WITH IT SIR.??
#4
EngineMan
EngineMan
Crankcase Vacuum Test
A partial vacuum should be present in the crankcase when the engine is operating. Pressure in the crankcase (normally caused by a clogged or improperly assembled breather) can cause oil to be forced out at oil seals, gaskets, or other available spots.
