Murray with tecumseh 17.5 engine
manowar
dies after taking off choke or when trying to throttle up. cleaned carb.fuel tank. fuel line and replaced fuel filter. getting fuel too carb float operating but has some kind of solenoid with power and ground on carb bowl. could taht be the problem
Doubt that the solenoid is the problem. I would clean the carb again and put in a new needle and seat.
EngineMan
Clean the main nozzle (jet) and engine number's would help us here so post them up.
