Murray Weedeater Brand New
artrip
I just bought a Murray 2 cycle Weedeater today from walmart. Took it home and put it together and put fresh 2 cycle fuel in it, It cranks fine and Idle's fine but will not throttle up real good. It has a slight bog to the engine when throttling it up. How can i fix this weedeater?
Like most new trimmers, they are too lean from the store, May be able to richen it up slightly, if you can find a way to adjust the carb, without the special tool. If it is one of the strada charge trimmers (Looks like two intakes on the carb) a slight bog is normal because the clean air mixes with the fuel mix air at higher speeds.
