Murray tractor
MW1961
Greetings,
Finally got around to mounting my sleeve hitch and adding a linear actuator need to finish the mount properly and dress up the wiring but it works, sleeve hitch was is Elitewill ebay $186.00 linear actuator was $42.00 on amazon tried using the sleeve hitch with the handle killed my shoulder also welded up some ground engaging attachments. 01.JPEG03.jpegimage0.jpg04.jpeg
For what purpose are you attaching this piece?
Make the terrain very flat and continue with grass or turn over the land to plant something different?
