Hi, I'm new to fixing mowers and I am at a bit of a stand still with this old Murray I bought. When I turn the key I get nothing. Not a click or anything. Headlight won't even come on. So far l, I have confirmed the battery is good and charged, replaced the 15 amp fuse going from hot solenoid post to ignition switch. Changed at the ignition and solenoid. I have verified that I am getting power from ignition to spade connection on solenoid.
I have verified that I am getting power from battery and between solenoid post. I checked the cable going from solenoid to starter and it has continuity. I can bridge the solenoid with a screwdriver and it starts up fine. Also headlights do not come on when running
Worth noting the seat safety is working, the PTO safety was bypassed when I got it and I have bypassed the brake/clutch safety for trouble shooting purposes. So I don't think it's a safety switch at this point.
So I guess I'm asking is this something I've missed checking? Anyone have any insight into this problem?
