I've tested the battery, replaced the spark plug, replaced the fuse, and even replaced the solenoid, and it still won't start; not a spark/won't turn over. Then I discovered that the right rear wheel is seized up & won't turn. I'm guessing this is a rear-wheel drive. I depressed the brake pedal several times thinking something might be stuck. I can glimpse underneath and see how things run from the brake to the back right rear wheel. I am a single woman & trying to fix this on my own. I've looked online but can't find any information regarding something like this. Any ideas what it might be? It was running just a week ago. Thank you.
