Murray rider/noisy vibration in drive
DarolW
I've had this mower for 5 years and has worked great. No idea what year it is. Model # is 24762A, the "Date" numbers are 1357. No idea what that means. It's an 18 hp, hydrostatic automatic drive w/46" width.
Anyway, when starting up this spring, it stated making a noisy vibration under it. The whole mower vibrates. When I push the peddle to release the drive, it stops. Seems to be coming from middle to rear underneath. I checked the oil for the rear drive and it looked fine. Kind of hard to get it up enough to get a good look under there. Any idea what could be causing this? Worn belt maybe? Hate to start throwing parts at it.
DarolW
Here's a picture of it. Probably in the early to mid 2000 model.
Fish
Maybe just a belt with a big chunk missing.
DarolW
I just checked the belt and it's in pretty good shape. A little checked here and there. Wouldn't think that would be an issue, though, I don't know much about these critters either. I was thinking about dropping the mower part and have a better look at things. Looks like it might be a real chore.
Fish
First off, we need a correct model number. The tag should be under/behind the seat, and if the deck is a 46", then the first 2 numbers should be 46
DarolW
My apologies on the first number. Grabbed the wrong one. Here's the one you want.
Partially or fully siezed idler pulley on the tranny drive belt.
DarolW
OK. I went out and checked both pulleys just ahead of the tranny. They both seem to be fine. I took the left one(sitting on mower /left side) off and it seemed fine. Would that be the one you're talking about? Anyway, the belt does seem to be flopping around quite a bit when engaged. Think maybe it's just worn/stretched out and not fitting the best? Any other ideas too.
I really appreciate the help.
DarolW
If I need parts for this, can you guys tell me what year it is by the info in the picture of Model #?
OK. After looking around the net, I think I've narrowed it down to a 97. Correct me if I'm wrong.
Fish
Error
1996, take the belt all of the way off and inspect things closely, bad pulleys, or a burned/shallow spot on the belt...
