murray model 309029X92C
That Guy88
I have a wire that connects from the stator or alternator that is dual charging. the wire that I have that connects back to the chassis wiring harness has 3 wires one orange and yellow that connects to the engine wire connection. then there is a black wire that was not connected when I took it off. Just trying to figure out where the black wire goes.
That Guy88
Here is a wiring diagram for your unit which may help you out. I’ve also attached a Briggs charging system service manual which may also help you.
Thanks I do appreciate it greatly
