Murray 30 inch rear rider only sputters in low/mid idle
semimechanicman
  • / Murray 30 inch rear rider only sputters in low/mid idle
I installed a new carb on this mower and it runs great, but just on full throttle. if you try to put it on low idle it misfires and sputters and eventually dies. Any help?
13AC26JD058
Bertrrr
I know it's a new carb but sounds like it has a port that may be dirty , your tank might have trash in it
Tiger Small Engine
13AC26JD058
Why did you install a new carburetor? Did you keep OEM carburetor? Sounds like pilot jet is partially blocked or too lean on new carburetor. It isn’t always a 100% match on aftermarket carburetor installed on a small 4-stroke engine.
semimechanicman
i put it on because old carb only ran with choke on
You should be running full throttle all the time. As in all the time. No reason to idle down a mower engine. Full revs for max cooling and lubrication. Also cuts and vacuums better.
semimechanicman
maybe but i plan on selling it and it shouldn’t be doing that anyways
Fish
Put up a pic or two of your carb, so we know what you have.
If you didn’t replace with an OEM carb, there is a definite possibility that the new one is jetted wrong for you engine application.
