Murray 20'' Push mower
alumwizard
I am having a problem with my mower ,it will start and run but every once and a while it will start to shut off ,so i bounce it slightly on it's wheels it starts running great again ,The carb has no Bowl or Adjustments ! Can someone please help me fix this as i had cancer ,and just got done fighting to keep my bladder and Kidney and now no more Thank God ,But this Mower is about to stress me out so any help will be great!!Thanks Jim
jcsmith
What model number is on the front of the shroud? Is the carb on the fuel tank? If so it might be the diaphragm under the carb. See your other post as well.
Hope your health is improving. Chris
LazerZLandscaping
Clean the carb if dirty, check spark plug, check oil, clean air filter.
If anything needs replacement, replace it and if anything needs cleaning, clean it.
