truckermatt
- Oct 6, 2013
- 1
- 1
Murray 10hp Tecumseh no fuel to carb
Hello On my tecumseh TVM220 motor i get no spark under normal conditons.. But when i remove the green wire from the ignition solenoid i get spark.
Also, The mower sat for many years, and when i got it, it would start with (wire removed) but would surge badly and only run with about 1/2 choke.
So i took off the carb and cleaned every hole with wire and carb cleaner, but i put it back together and it cranks over with spark but no firing up.. Fresh gas and a new fuel line were used ( the old one had oil-gas residue in it.)
fuel is flowing from tank to the carb but then it stops, when i took the carb off again it was completely dry from the first time still.
Any advice would be helpful Thanks, matt
