murray 10/30
gerard35
hi people ive a 2 old murray 10/30 ride on 99, iam currently take parts from 1 to the other, ive started with the STARTER SOLENOID so i wired it up but it wouldnt start with the key yes the SOLENOID is workin, so i jumped it with pilers but it just makes an noise, so i took the plastic bit to look at the starter off, then i tryed starting off the jump again but the starter gear just spins, so checked the teeth on the ring it looks ok. its a briggs and stratton 28a707 its a murray model number 30560x20c
thanks gerard devine
