Hi All,
I am adjusting the tension on my mule belt for my 60" lazer. Im a little confused because the manual says the bolt needs to be in the center of the aliment holes, than on the next line it says it needs to be on the top of the bottom hole. What is the correct way to adjust it? There is not way the center of the bolt can drop that low. If I follow the manual it also says push the fixed idler pully all the way down the slot. When I do that the spring is almost all the stretched out 1/2" (or less) away from hitting the top of the frame. Can someone help before I ruin an expensive belt???
