Its common to get grass blowing out the right front corner of the deck when mulching.  You very well may find that you get more grass on yourself and the mower and you'll be limited by having to slow down in heavy growth and will make a mess if the grass is wet.
Oil consumption seems a little high.  What are you using for oil?  I find my machines burn a lot more if I run 10w-30 as opposed to straight 30.
