Mulched Grass Coating Right Rear Tire
LarryJohnson
What causes the right rear wheel to be coated with mulched grass while the left one stays clean. I know the grass has to go somewhere with a mulch blades and cover installed, but it seems like it's still forced towards the right side exit. Cleaning out under the deck today I noticed that there was absolutely zero build up above the left blade, but the right side deck was packed with grass. Why does one get packed while the other is clean. All blades are new. The left side spindle is new while the right side is old, but has been greased.
