Engine Muffler Replacement
GYL
Need to replace muffler on Toro 265h with Kolher mod cv15 engine. I have removed old, but can't figure how to install new. It appears the engine has to be pulled in order to install new. Anyone have any suggestions?
the fact that the muffler mount is on the bottom of the head on the Kohler, almost requires that the engine be removed to install either the nuts on the studs, or to instal the bolts. I have installed the muffler on other mowers with that engine, and can be fun if you have fat fingers.
Buckshot 1
:smile: How did you get the old one off? Just reverse that procedure.
