Hi my brother broke the balde off his Yardword mower MTD OEM I think.
I opened up the top head of the mower and inspected the piston and valves for damage. I found none so I just cleaned everything up removing all the carbon build up.
I did not adjust the vavles.
After cleaning the carburator I was able to start up the engine but noticed that it does kick back.
I tried starting it again and broke the pull cord and then tried to start it with a drill and experineced the same kick back.
I saw on YouTube videos that a broken flywheel key can cause the kick back.
Here is the sticker on the engine.its a 173 CC OHV made by MTD model : 6CZHS 173 FV ?
the model is :
The impact to the blade broke off the blade shaft adapter
Pictures of the flywheel and key
We can see a small gauge in the key channel . Is this flywheel done ?, causing the kick back or could it be cause by the fact I did not adjust the valves. ?
the key looks fine to me.
Mover with valve cover off.
My next corse of action should be to try and adjust the valves but I a not sure of what process I have have to follow. I do have some "feeler guages" for the valve adjustment.
I am I heading in the correct direction or id the flywheel damaged.
thanks for any suggestions
the model is :
