I have a 2007 TroyBilt mower with a Self Propelled . It's transmission has a cracked transmission engagement lever. I am not sure if I buy a new transmission, it will include this lever. I like LawnBoy's idea better. The OEM number for the transmission is # 918-04492A. Does anyone know if there is a OEM number for just this plastic engagement lever ? Any help would be greatly appreciated.
My TroyBilt mower is a 2007 Model # 12AG836E011 . This lever is plastic and it engages the transmission while pressure is on it. I would appreciate any help you can give me. Thanks, Glenn
No, Sorry, But this kit is the lever you squeeze at the handle to activate the self propel of the mower. The engagement lever I am looking for comes on transmission part # 918-4492A. The drive cable attaches to it and when you squeeze the lever, it pulls this plastic lever and engages the transmission and also tilts back the whole thing so the belt tensions. I hope this makes sense.
#9
BlazNT
Trans has no rubber or plastic part on it. So it must be either this 735-04059 Rubber Grommet or this 946-04265A Drive cable.
If you look at part # 753-05351 , you will see the lever I am looking for. Apparently is not available. But this is the transmission I need. I just wish there was a way I could put a Lawn Boy transmission in this mower instead of this one. With Lawn Boy, all you do is pivot back on the transmission , to engage the belt. With this idea, this lever engages the transmission when you squeeze the lever. With mine, the lever is cracked, so when you pull on the lever, the lever doesn't engage the transmission . I guess I will just have to replace this transmission.
#11
BlazNT
You should find a sticker with a model number on it on the trans. With that I can find the part you are needing.
Here is a pic of the transmission on my mower. I know this is the model is most likely made in China. I was hoping to get a more substantially made one , thats why I was looking into the MTD part number. ( 753-05351 ) . If I can not buy this engagement lever for this transmission , then maybe this mower will be a good pusher ! LoL
