davbell22602
- Nov 27, 2011
- 152
- 1,324
Anybody have a MTD service manual for this Sears track snowblower? 247.888500
New rubber drive disc
New friction drive disc
New drive/auger belts
Will roll backwards in transport setting but not forwards. When in normal or wet snow setting and when the drive cable is too tight I get the power steering to turn to it left or right in standing still position. Bearings not seized up on the shaft that wheel disc assembly goes on. Turned freely when had it apart this Saturday. Auger was froze up but got loose with rubber strap wrench on the 2 auger belt pulleys.
Tried going by the instructions in the owners manual but either didnt fully understand by how its worded or its not worded very well.
