18 Yard-Man/MTD
42"
16 hp, original engine
About 500 hours on it
NOT hydrostatic drive, it is a belt drive
Yesterday finished mowing about 2/3 of an acre, during the mowing the following happened a couple of times.
1) mowing along in 4th gear
2) forward motion slows from normal to 50% over the space of about 3 seconds but ENGINE IS RUNNING *AT THE SAME SPEED*
3) this last for 2 or 3 seconds, short enough that I'm not certain it is happening
4) then forward motion resumes at normal speed
I finish mowing then park it, then do a little testing and the following happens.
1) moves forward just fine for about 5 seconds after starting, then slows, then stops but ENGINE IS STILL RUNNING AT THE SAME SPEED
2) does *exactly* the same thing in reverse
3) when I switch from forward to reverse (after it has stopped moving), or reverse to forward (after it has stopped moving), it runs in the appropriate direction for maybe 3-5 seconds, then slows down but the engine is still running at the same speed
My guess is belt related but I don't smell any burning or heat, no smoke from burning grass underneath. Note belt is only 1 season old, maybe 25 hours.
Mower is pretty worn out so I'm trying to make the decision to kill it or not.
Suggestions?
Many thanks,
Dan
42"
Suggestions?
Many thanks,
Dan
