mtd riding mower won't start
oneace
I replaced the solenoid, coil, checked to make sure starter was good,replaced fuse and still will not start not even a clicking sound. please help
gfp55
Maybe you could post the model# serial# of your mower and engine. Is the battery good and charged? How did you check to see if the starter is good? You might check the ignition switch also. Check all the connections, wire to starter, ground wires, etc. to see if they are clean and tight.
