LawnBoy97
- May 30, 2012
- 33
- 223
I just got this from a guy on craigslist for really cheap. It is in okay condition, with a little rust, but it did need some work. The air filter cover, pull cord handle, and the bail? cable was broken. The spark plug looked almost new. Anyways, I got it home and then looked under it today and noticed that the tip of the blade is bent at nearly 90 degrees. There is also some oil under the engine and it seemed as though someone had jammed a rock into, I think, the governor. Which I guess the jammed governor could explain the bent blade. So I cleaned out the carb and then started it. It started and then smoked, but I didn't run it enough to see if it would go away. It did vibrate quite a bit, but I am just not sure if it is the crankshaft, or if it is only the blade since it is bent so much. I drained the oil and it seemed to have a smell to it, but I didn't notice any metal particles. When I removed the carb, it did look like there may have been some moisture right inside the engine, but the carb had no corrosion. If anyone has any ideas or needs some more information, please post. Thanks
I should add that the top of the crankshaft does not have engine oil on it. It is only wd40.
