Hi I have a yard machine 16hp 46" cut mower that I am working on, My problem is that there is no model or serial # tag on it and I need it in order to get info about the mower. I removed the belts without drawing a diagram of them and now I cannot get them back on properly to make the tractor drive.
I removed the belts because they were cracked and the tractor would start off going fast then slowdown. Could the variable speed pully be at fault for this.
If anyone has a diagram of the belt routing it would help alot or does anyone know where to get one? keep in mind I dont know model or serial# thanks for any input
