peterfrain1943@gmail.com
- Oct 27, 2012
- 6
- 13
tractor engine runs fine, until i engage the blades. then the engine starts to miss, sputter, and i think it would stall. (cant cut the lawn) then runs fine when i disengage the pto . have changed spark plug, air filter, gas. have also checked under deck for debris--seems clear----cleaned built up grass also. all belts fairly new and seem to work properly(not smoking).
i have posted this before---help!
