mtd 32 inch cut lawn tractor
engine runs fine until i engage pto--then the engine starts to miss and sputter and die. tractor runs fine if i do not try to engage the pto-----------help need to cut the lawn
cambre
Did you look under the deck to see if anything got caught in blades. With engine off see if you can turn blades by hand. See if belts are free. Might have frozen pulley bearing.
