mowing uneven
1chase
I have a 46 in. mower deck that is not mowing even is there a certain arrangement that blades need to be on, or order or spaced?
poloman
Your deck can be adjusted so that the left and right sides are even. Measure from the blade ends to a solid surface.
SONOFADOCKER
All decks have front of read adjusters . Get your level out and check the four hanging locations - its pretty easy to knock it out of balance with a bump against a tree or fence post .
wfrpalm
I hit a stump with my blade and it bent. It caused uneven mowing.
redfish9
Sounds to simple but check the air pressure in your tires too
