So at the end of last season my 10641 20-Inch Briggs & Stratton 675 Series Gas Powered RWD would not start. I ended up cleaning the carb and it would work, after a couple weeks sitting it wouldn't. So then I bout a rebuild kit for the carb and replaced the gaskets, cleaned it real well, and it worked great... until it didn't (I also used seafoam and soaked it in the spark plug "chamber" which seemed to help). So the start of this season it works fine, after a couple months it doesnt start.
Last week I soaked the spark plug chamber in seafoam again and it seemed to help. I was able to mow my lawn. Today... won't start. Rather than soak the spark plug trick again (seemed like a bandaid) I opened the carb to clean it... but it "looked" pretty damn good. What might be the issue? Is this mower just a piece of junk not meant to last? I probably had it for 7 years now. Did the yearly oil change, sharpened the blade every 2-3 years, I felt like I took pretty good care of it for what was mild small residential use about 1/3 acre lot I would guess).
Curveball..
Unfortunately, I was just screwing a screw that connects to the shaft throttle and that part of the carb housing literally broke off. A new carb appears to be $50 and I'm not sure it's even worth it if this mower is done for anyways.
Thank you for the help.
(attached a photo of the breakage)
To clarify, I suppose at this point my question is 2-fold:
Is this mower worth fixing?
What went wrong so I don't do it again (I thought mowers should last considerably longer)?
Curveball..
