Export thread
Mower won't start
#1
T
tomekkplk
I have a Troy-Bilt 33"WC with the 8.5 I/C engine. Model 196702, Type 0112 01, Code 95011T41B. Lawn is finally dry enough for me to mow my lawn and I cannot pull the cord. I turned it over and the blades move freely. All belts were replaced before last season, never ran the engine out of oil and has a new spark plug every season. Some research came to a common problem, engine seized due to oil starvation and carb leak getting gas in the oil? I've owned this mower for 6 years and never had a single issue with it even first starts of the season. Anybody have any ideas?
#2
Dguerra83
Dguerra83
#3
Dguerra83
Dguerra83
Try taking out spark plug and pulling the cord.
#4
Lawn Mower Repair Tulsa
If your Troy-Bilt mower's cord is hard to pull, check oil levels and the carburetor for leaks. If that doesn't fix it, seek help from a repair professional.
#5
It sounds like your mower might have an issue with oil or the carburetor. Check the oil level and carburetor for problems. If unsure, consider consulting a mechanic. Good luck! Visit Now: https://lawnmowerrepairtulsa.com/
